Interior fan issue
Old 02-22-2014, 05:59 PM
v64thgen's Avatar
Default Interior fan issue
The interior fan quit working on the highest setting. I know there is a separate relay or switch or fuse (not sure which one it is) for it, it still works on all the other 3 settings. What is it called? Where is it under the dash? And how do you get to it, does anyone have a how to? 94 v6
Old 02-22-2014, 08:06 PM
Old 02-22-2014, 11:21 PM
v64thgen's Avatar
that sounds about right, thanks
Old 02-22-2014, 11:53 PM
v64thgen's Avatar
this is the 3rd time in a year and a half this relay has died. does this suggest something else is causing it to crap out, or has the shop I took it to used a crappy relay?
Old 02-23-2014, 06:18 AM
how is the fan working, any funny noises or poor performance? could be the blower resistor. found this on a search
It is on the passenger side, you have to remove the black plastic kick plate, below the glove box, to expose it (held in place with 2 latches and 1 push pin). The resistor is in front of the blower motor ( sandwiched between the motor housing and the firewall) it is tricky to get to,
Old 02-24-2014, 08:11 AM
v64thgen's Avatar
the fan sounds normal, and works perfectly on all the other speeds
Old 02-24-2014, 08:17 AM
if mine has the extra speed for the blower then its not working so i will be looking at both the relay and resistor.
riddler27
08-03-2011 03:14 PM
jason7504
11-04-2008 12:16 AM
purplepeopleeater
10-08-2008 09:46 PM
divvichild
12-24-2007 06:53 AM
Quick Reply: Interior fan issue
