intake maniflods?
Old Apr 24, 2008 | 12:27 AM
Jokers Z's Avatar
Default intake maniflods?
i have heard good things about the fast intakes, but how good are bbk's? or is there any other good intakes?
Old Apr 24, 2008 | 12:55 AM
95slvrZ28's Avatar
Default RE: intake maniflods?
What year do you have? If it's an 01 or 02 you already have an LS6 intake on the car. You aren't going to see any real power gains over an LS6 intake if you don't have any internal mods. If you're thinking about doing new heads and a bigger cam, then you could consider the FAST intake, but you would need to get the 90mm TB version to see any real gains.
Old Apr 24, 2008 | 10:56 AM
JD1969's Avatar
BBK is total junk. Either go with the LS6 or the FAST. I put down over 400 rwhp with a stock LS6
Old Apr 24, 2008 | 07:25 PM
Jokers Z's Avatar
i have a 98 z. i plan on doing mods i dont know about heads but definatly cam roller rockers etc. hopefully getting around 400 to 500 horse. i was also wondering that what make a camaro a m6?
Old Apr 24, 2008 | 08:48 PM
qmracer's Avatar
Are you asking how to make one an M6 or what M6 is. If you just want to know what it is it is the Manual 6 speed transmission. If you are asking about converting you would probably be better off buying a different car.
Old Apr 25, 2008 | 10:42 AM
JD1969's Avatar
ORIGINAL: Jokers Z
Your not going to see 500 without heads, unless you add nitrous. 400 is doable with a cam and bolt ons, but you need a pretty big cam. BTW your stock rockers are fine as well, I know 9 second cars that run them without any troubles.
Old Apr 26, 2008 | 05:09 PM
camarosam22's Avatar
I would go with the FAST, because down the road its a better manifold, b/c eventually you might decide to put a cam and heads on it, and having the FAST will make a big difference, alot of money but better for the long run.
Old Apr 28, 2008 | 12:25 AM
Jokers Z's Avatar
Thanks. ill do that
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
Bzman
Apr 18, 2008 05:27 PM
Goodfella
Aug 21, 2006 07:46 PM
