LS6 intake?
Old Apr 16, 2008 | 06:06 PM
Bzman's Avatar
Default LS6 intake?
hey guys, brought my car to chevy to get inspected, they said there's a pretty big leak in the intake manifold which would run me $500. But I was thinking it would probably just be more cost efficient to replace the intake with the ls6 instead of getting this fixed then replacing it, right? What i didn't know though is apparently there are different brands.I've seen slp (which i would imagine is overpriced), gm and others. are they all the same, which one should i get?
Old Apr 16, 2008 | 07:14 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: LS6 intake?
the GM replacement isnt a bad one. its the same one that came on 01+ ls1's. if youre going to do more than that save up for the FAST intake
Old Apr 16, 2008 | 07:28 PM
Bzman's Avatar
well the thing is, i have my car at the chevy place now and they were going to fix the intake for $500among other things, so i figured while i have it there, instead of paying twice, why not just upgrade the intake which would probably be around $500 as well. I didn't know that the ls6 was on the later model ls1's though, doesn't seem as fancy shmancy anymore. how much do FAST intakes run? i wasn't looking to spend that much on an intake as i plan on doing a CAI, LT's, high flow catted y, c6 wheels/nitto 555rs, and gears. So i was going to do everything relatively inexpensive (ie: pacesetters > kooks). is the ls6 worth it?
Old Apr 16, 2008 | 08:12 PM
Ninja Administrator
ls6 is worht it if ur getting a cam. i dont have one yet, wish i did. I may try to find one here shortly. the fasts are like 800 tho at least. get the ls6
Old Apr 16, 2008 | 08:41 PM
95slvrZ28's Avatar
The FAST manifold is only going to get you any good gains if you go for the 90mm TB and intake combo, and even then you're not going to see full gains from it until you have heads and cam on the car. Go for the LS6 intake unless you're planning on doing big things in the future.
Old Apr 16, 2008 | 09:32 PM
Bzman's Avatar
k thanks. I figure the difference of them fixing my stock intake and the ls6 is probably a couple hundred dollars so its worth it if i plan on doing full bolt ons and probably a cam at some point? or should i just let them fix the stock one?
Old Apr 16, 2008 | 09:40 PM
Ninja Administrator
IF you plan to do cam and boltons in the future u might as well because it will be cheaper this way in the long run.
Old Apr 16, 2008 | 09:41 PM
Bzman's Avatar
thanks spec
Old Apr 18, 2008 | 01:26 PM
LT1RUNNER's Avatar
To bad they don't make any aftermarket intakes for LT1's.
Old Apr 18, 2008 | 01:32 PM
Ninja Administrator
LT4 intake?
