Im F***ed!
Old Oct 13, 2009 | 10:19 PM
750chop's Avatar
Default Im F***ed!
Re-installed the trans. its Fubar. only got 1st and 3rd and i can manual shift them only
Old Oct 14, 2009 | 10:24 AM
did u do the rebuild ur self? take it back if not. if so check out the fac and tech section here and see if u can find anything.
http://www.700r4l60e.com/
Old Oct 14, 2009 | 10:32 AM
750chop's Avatar
i didnt rebuild it, i just replaced the front and rear seal. thanks ima take a look at that site now.
Old Oct 14, 2009 | 11:25 AM
So it worked before you took it out to replace the seals, and now it doesn't? Have you checked to make sure you didn't mess up your shift linkage, or you didn't forget an electrical connection?
Old Oct 14, 2009 | 10:00 PM
750chop's Avatar
yup. Evry thing is hooked up, took it to Aamco for a free diagnosis and they say the band that engages 2nd and 4th are garbage
