i think its not true
Old Feb 10, 2010 | 04:51 PM
Carl Dan's Avatar
if you have a stock amp for the monsoon system it should be behind the spare tire on the rear right fender bracing. i can't recall where the bose amp was or if it was in a different location.
Old Feb 10, 2010 | 04:52 PM
Carl Dan's Avatar
how many speakers are in the car?
Old Feb 10, 2010 | 04:56 PM
thetal1's Avatar
From the factory 4. Now 6 cuz I put 2 subs. So the base model cassette radio had an amp to power the door speakers?
I have a pioneer deck and after market door speakers if that helps.
Old Feb 10, 2010 | 05:26 PM
libertyforall1776's Avatar
Better do a search in the AV forum... Scoche has an adapter u should look into:
Scosche OEA-4 C4GM02 adapter
http://www.amazon.com/Scosche-4-Chan.../dp/B00009UHSO
Old Feb 11, 2010 | 10:54 AM
thetal1's Avatar
So what im getting is that no matter what radio you have there is an amp seperate from the factory radio thats powering the door radio?
And since i replaced the factory radio there is still an amp in my car that came from the factory?
Old Feb 11, 2010 | 12:50 PM
if u dont have the bose or monsoon u dont have the amps. i think the issue is do u have the sw outlets on the stereo and are u going to use them with proper wires going to the amp or are u going to run directly from your stereo speaker outlets to the amp. do a seach on crutchfield and see if they have your stereo and amps u want to use, if so then see what is needed to hook them up.
Blazey
Jan 25, 2012 10:41 AM
ralph03
May 3, 2011 03:46 PM
Godzilla179
Oct 11, 2010 09:54 PM
02CamaroV6
Oct 18, 2006 09:43 PM
