I Need Some Opinions.
#102
A few more.
Right now I am just letting it sit until the snow passes, then once warm weather comes I'll clean it up and start working on it.
I didn't notice this until I got it home, but you can see where it's cracked on the passenger side mirror. Ebay has them for cheap so that's 1 thing that I'll have to fix asap.
#104
That will need some TLC also. The white spots all over annoy me, but they come right off with a wipe of the finger. I plan on cleaning it all up once it warms up.
and for those who have installed amps, where did you run the power wire @ through the firewall? I'd like to keep it straight back from the battery if possible.
#105
Love the limited edition badges... They are from a Mercury or Lincoln if memory serves.
Still looks like you got a good deal. The crack in the pass side that I seen is actually part of the fender not the mirror.
Massey
Massey
#106
Yeah, that part is cracked, too. I guess you can't really see it that well but on top of the mirror and all the way down to the fender is cracked also.
#108
theres a rubber piece in the cubby under the passenger side hood hinge, under the ecu, you can make a small hole in and run the wire through. that will get you into the passenger compartment.
