I need help!!!
Old Oct 24, 2010 | 10:12 PM
Handles92's Avatar
Default I need help!!!
I have a 95 3.4 l camaro, and i need a new bellhousing. I can not find one at all so i was wondering if anyone knows where i could get one, or if another kind would fit. Thanks in advance
Old Oct 24, 2010 | 11:15 PM
Massey's Avatar
I am not sure but have you looked at a 2.8L Camaro or S10 with a 5 speed? The engines are the same I dont know about the bellhousing. The only other thing I can say is call around your local Tranny shops or see if a welding shop can put yours back together. (if it is broken that is.)
Massey
Old Oct 24, 2010 | 11:52 PM
what trany, 5 sp or 6sp
Old Oct 25, 2010 | 06:43 AM
Handles92's Avatar
i have a 5 speed
Old Oct 25, 2010 | 07:12 AM
RFxCamaro's Avatar
ive seen those tranny all day at the junkyard $100 for the whole tranny
Old Oct 25, 2010 | 10:00 AM
im showing the same bellhousing for the t5 for 3.4 and 5.7. does yours look like this
http://cgi.ebay.com/ebaymotors/82-92...s#ht_500wt_956
Old Oct 25, 2010 | 11:15 AM
Massey's Avatar
Not sure how they can be the same since the 3.4 uses the 60º bellhousing and the 5.7 LT1 uses the old Chevy pattern. I could see the 3.4 and the 3.8 using the same one, and I am not sure about the bellhousing pattern of the LS1 I have not had one sitting on my floor yet.
Massey
Old Oct 25, 2010 | 11:19 AM
thats what i thought but my 93 parts book only shows one for the 5 spd. must be a misprint.
Old Oct 25, 2010 | 11:21 AM
What in the heck is showing 3.4 and 5.7 bellhousing is the same. 3.4 and 2.8 is the same, but different from the 3.8, and those are different from the V8.
Old Oct 25, 2010 | 11:30 AM
Massey's Avatar
Depends on the 3.8 engine. The older RWD 231's or 3.8s used the BOPC bellhousing while its FWD counterpart used the 60º bellhousing. The Series II and Series III both use the 60º bellhousing which is the same for the 2.5, 2.8, 3.1, 3.3, 3.4, and 3.8 that I know of. Many other engines may share the same pattern as well. The pattern on the block may be the same but that does not mean the bellhousings are the same, nor the flywheels or clutches.
Massey
