i just changed my oil and now it wont start. please help!
Old 08-09-2007, 05:55 PM
Default RE: i just changed my oil and now it wont start. please help!
The clicking is the solenoid making and breaking. Most times that is caused by the solenoid not getting enough current. Could be a weak battery, bad battery cable or connection, alternator not keeping the battery charged, or a bad starter.
Old 08-13-2007, 10:43 PM
hvacben's Avatar
I actually just had a similar problem with my 2000 SS I just bought it and like 3 days later it had trouble starting. I thought it was the starter relay but it turned out to be a bad starter. Is the clicking noise coming from your fuse box? If so this may sound wierd but take a rubber malet at tap your starter motor then turn it over if it starts after that you have a bad starter motor. If not something electrical most likely.
Old 08-15-2007, 06:20 PM
1994greenchevy's Avatar
yeah sounds like an electrical kind of thing. notfully shure of what it is.
Old 08-17-2007, 10:26 PM
Mr.Locs's Avatar
that click click click sound is your starter, if you turn it one time and it just makes a load click thats the cylinder in the starter, and needs to be replaced, oh yea and make sure you completely drained all of the 20W50 out before you added the 5w30, cause 20W50 is fully synthetic oil and most 5w30s arent full synthetic and if they mix and your engine starts to get to normal and over normal temp it can make your pistons lock up, we had someone do it at work they didnt drain all the oil out and added 5w 30 oil to it and the **** locked up, we had to take the engine out drain the **** and take apart the engine block and take the pistons and camshaft out the customer wasnt happy, i never new it would happen either so yea just warning you now
mrfreez
04-06-2014 08:17 PM
91marrow
04-26-2012 05:24 PM
No1chixmagnet
82-92 V6 Tech
06-22-2010 12:38 PM
83berlinetta
82-92 V8 Tech
09-21-2008 08:44 PM
RSZ28SS
11-24-2006 12:14 PM
Quick Reply: i just changed my oil and now it wont start. please help!
