I heard Fram Oil Filter / Penzoil is Junk?? any truth?
Old Jul 16, 2007 | 12:06 PM
hackson's Avatar
Default I heard Fram Oil Filter / Penzoil is Junk?? any truth?
basically i did a little research and read that Fram OIL filters are junk, is there any truth in this or am I ok if i change my oil between 2-3k miles ?
Is the penzoil synthetic trash as well?
Old Jul 16, 2007 | 01:42 PM
Danscamaro02SS's Avatar
Default RE: I heard Fram Oil Filter / Penzoil is Junk?? any truth?
Alright ill tell you why penzoil is junk it is a wax based oil so in you engine wax is building up trust me on thisi used to be a penzoil fan til i help rebuild my dads 454ci in his truck with 115K that he also bought new in 79 the oil was change every 3000 and there was wax **** every where on the valve springs pluging oil passages etc. then on therebuilt 454he tried regular Valvoline 10w30 hehas 300k + on it and still runs like a champ.
Old Jul 16, 2007 | 01:46 PM
ya depending on how you drive 2-3k not bad at all i do mine every 3-4 months cause i dont drive mine that much i put 4k on it since i bought it last year
Old Jul 16, 2007 | 02:14 PM
hackson's Avatar
alright thanks, I will stay away from pennzoil
hackson's Avatar
fram is ok then i take it?
i got a "tough guard" by fram
Old Jul 16, 2007 | 03:50 PM
ive never had a problem with fram oil filters
Old Jul 16, 2007 | 10:27 PM
95slvrZ28's Avatar
The regular Fram filters aren't the greatest, not junk, but not good. I use Fram Tough Guard, they do quite well in tests and are considerably better than the regular Fram filters.
Old Jul 16, 2007 | 10:35 PM
74454bb's Avatar
May 2007 ROTM
I use the fram tough guard...but an oil filter is an oil filter...even an ok one works good.
Old Jul 16, 2007 | 11:26 PM
94Red's Avatar
I find that using the K&N Gold Oil Filter is the best ive ever used, a little more $$$ but its well worth it, plus i use Royal Pruple oil
Old Jul 17, 2007 | 09:30 AM
hackson's Avatar
i talked to someone and they suggested that most companies have a "cheaper" and "premium" filter....I will stick to the fram tough guard when using fram
