I hate being stupid [and unfamiliar with automatics]
Old Nov 1, 2008 | 07:00 AM
ThorOtheBIG's Avatar
Default I hate being stupid [and unfamiliar with automatics]
Okay so I was driving around in my Z/28 with a couple of homies in a lame-o honda. Anyway, we were at a stop sign so I diceded to go into neutral and rev up a bit (since dude just got an exhaust and thought it was cool, but wasn't). Any moron knows not to kick it into gear (with an auto) while revving. Don't worry, I let engine return to idle before I popped it into drive... But I failed to remember to let the tranny get into gear before I start to leave. I didn't step on it, I treated it like I was rolling from a stop light. But, nontheless I gave it some gas when it was getting into gear. The whole damn center console jumped up (not literally, lets just say I thought I blew the trans)! I slowly gave it gas just incase the trans was damage. It was okay. Shifts okay, but I just can't give it too much gas from a start. Basically, I think I busted a tranny mount. I have seen some on www.rockauto.com for about 10 bucks. Plus it was highlighted so I assume it is a common fix.
Sound like my problem?
Thanks
-Bo
Old Nov 1, 2008 | 05:52 PM
gvmv's Avatar
Default RE: I hate being stupid [and unfamiliar with automatics]
Yeps sounds like you busted the mount. Easy fix.
You can see pictures from fixing mine here.
Old Nov 1, 2008 | 06:52 PM
Great! Thank you sir!
Old Nov 1, 2008 | 07:20 PM
th3po1son's Avatar
Yeah the first time that happened to me I was REALLY freaked out haha. I guess they just wear out over time.
Old Nov 1, 2008 | 11:23 PM
95slvrZ28's Avatar
Go with the Poly mount this time instead of the stock one, then you won't run into this issue again.
Old Nov 2, 2008 | 01:08 AM
Spartan66's Avatar
polys run stiffer than stock. just be prepared for that.
Old Nov 8, 2008 | 12:28 PM
outta_control_z28's Avatar
yup much stiffer but last sooooo much longer !!
Old Nov 8, 2008 | 02:22 PM
Nessy's Avatar
ya, with a broken tranny mount it will feel like the trans is coming up through to center console when you step on it. It's like a 15 dollar part, and a easy fix. Don't take it to a shop, or if you do, give them like 10 bucks, it takes like 5 mins. Don't buy into a half hour or hour book time and end up way overpaying for it.
Old Nov 8, 2008 | 09:34 PM
Spartan66's Avatar
Ive got a bad tranny mount on my Eclipse. when i try to accelerate up hill or on the freeway in higher rpms it shifts hard.. but theres a million DSMs between the 2 local junkyards and i can get a used one that i inspect personally for 20-30 bucks.
rancheronut
May 24, 2009 11:17 PM
greenarrow
May 9, 2009 12:44 PM
traumadog
Nov 16, 2008 09:51 AM
