how tight for sway bar links?
If using poly replacements, do not smash the poly, only tighten enough so there is no play in the link, else the poly will deform.
LS1TECH - View Single Post - Rear sway bar problem.... (with pictures)
thanks for the info, I didn't tighten them as much as the one in the picture. and I just went with standard rubber
