How to remove This Plate
Good day. I have this problem with the part under the streering wheel. I have tried googling and looking everywhere for too long. First we tried to pull it out but it did not come. So my friend asked from some dealer repairer how to do it and they said push it in a little but i think they confused it for the lock plate? Atleast i have looked on images and some tutorials show removing the wheel and none include taking out this ****.
Here is pucture its the rusty looking metal thingy
ImageShack® - Online Photo and Video Hosting < seems like it put the text for link like that for some reason.
Im getting little desperate :P
May I ask why you want to remove this. Is the flasher assembly in nead of replacement?
Last edited by impala765; Jun 28, 2011 at 08:32 AM. Reason: Fingers don't type what the brain tells them too lolll
I need to change the turh signal switch. So it should not require too much force to go down a bit ? Could it be blocked by not being at right angle. I mean i have tried to push it with the lock plate removal tool looking one. and i think the metal plate istself is giving up rather it going any down
Thanks for reply
.Thanks for reply
Thanks for reply
.Thanks for reply
It won't go down alot cause the spring is already compressed. You just need stiff fingures and patients and a little flat screwdriver to pry the ring off. If it's like the one on the Impala, the ring will be tight on the steering post. Just move it upwards a bit at a time. You'll figure it out while doing it. Have fun.
ON any of the airbag columns I have rebuilt (and there have been quite afew) the air bag coil is held in with a snap ring. This can be easily removed with snap ring pliers. under that is the lock plate which takes a lock plate removal tool (rent or buy for about $10) and 2 small standard screwdrivers to pry the little lock clip out. DO NOT MANGLE this lock clip!! It holds the entire column bearing assembly in place (no joke here) just walk it up out of its groove and then slide it up the column. Visit this site here for tips: (he is building the column but you will get a good idea on what to expect)
http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
And before you flame me here lemme explain. Yea this is for a Fiero, but the basic column is the same. The base of the column is different but hte top and head are the same. Only other exception is the airbag coil which we should be able to figure out.
Massey
Massey
Echo DarkFox and Massey - - steering wheel puller and snap ring pliers are maybe $35 in tools that save 10 times that amount in blood pressure meds (or Jim Beam.)
Having fun with the air bag pack? I felt like a bomb squad member, holding it away from my face and telling my son to get the hell out of my way.
oh god your changing the turnsignal switch..... there are two clips, that one and an even harder clip after that :'( i had to give up on it and make a special tool for it from an old philips head (we grinded two of them down to a point) to put them into little holes on the second clip
