How low should i go
Old Oct 21, 2010 | 04:18 PM
je$$up97's Avatar
I installed a set of Eibach's that are supposed to be 1.75"...by the time they settle after a few months it seems closer to 2". This is a bit extreme and you have to be careful if your are using Long-tube headers and oversized wheels and tires. I cleared my stock SS 17x9.5's with 275/40/17's just fine...however, my front air dam for the radiator rubs on some large speed bumps. I think if you lower around an 1" you shouldn't have to worry about any of these issues. If you check out my garage, you can see how it looks on a set of 18's in front and 19's in back.
Old Oct 25, 2010 | 01:16 PM
je$$up97's Avatar
also, if you lower drastically, you will need to get an adjustable panhard bar to compensate.
Old Oct 25, 2010 | 04:16 PM
MelloYello's Avatar
Originally Posted by craby
you could pick up some adjustable koni struts and shocks, you can lower the front 3/4 in with them, then do the hose mod on the back, that lowers the back 3/4 to 1 in. strano told me how to do it when i bought my koni's,
what is the hose mod?
pass on lowering, im raising my rear end 1.5"!!!!! gettin the pucks off summit
