How do you take the valve cover off?
Old 11-26-2010 | 05:57 PM
Mustang_Eater's Avatar
Default How do you take the valve cover off?
Hi All,
My lifters are making that ticking noise and I want to take my valve cover off so I can check for slack in the lifters or if there is rod problems.
Anyone have any instructions on how to take off the vavle covers on a 1998 Z28 LS1?
Also, if I do find a loose lifter.. do I just tighten it down with a wrench? Is there specifc torque to these things.
Thanks!!
Old 11-26-2010 | 11:39 PM
are you sure its not a exhaust leak? if i knew anthing about ls's it would help. i know you have to take the intake manifold off to get the valve covers off. thats about it. i surprised noone has come back for ya, i can move this to the ls tech section if you want. may get a little more help there. maybe if no response by moring ill do that.
Old 11-27-2010 | 03:51 AM
RFxCamaro's Avatar
Go to autozone.com register for free and it will have a good walktrough, its more helpful than my chilton
Old 11-27-2010 | 03:55 AM
Massey's Avatar
Does the sound go away after the engine warms up? If it does it may not be a lifter but the normal piston slap sound that these engines make when they are cold. The 2001+ LS1 engine had a different piston that didnt make as much noise.
Massey
Old 11-27-2010 | 08:48 AM
Even if your problem is the lifter tighening up is not a good idea. Most of the time when you get a single lifter noise it is because a lifter will not pump up all the way. If you tighen it then it decides to "pump up" like it should it will cause all kinds of issues and may cost you a motor.
Try some seafoam in the oil, run it a day then change the oil with mobil one or better oil and see if it the lifter comes around.
jallen53
70-81 V8 Tech
02-15-2012 09:16 AM
DarlingReject
10-05-2010 12:31 AM
mstephens20
03-26-2008 10:23 AM
dvader
07-02-2007 12:17 PM
camarorz28
03-13-2007 12:41 AM
Quick Reply: How do you take the valve cover off?
