LT1/LT4 Tech 1993-1997
chrome valve cover
Old Mar 5, 2007 | 02:51 AM
camarorz28's Avatar
Default chrome valve cover
Hey anyone knows of some good tight chrome valve cover dress up kit. will these valve covers fit my 94z
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 5, 2007 | 04:56 AM
sellc's Avatar
Default RE: chrome valve cover
No them will not fit your Camaro. You the set with the notched passengers side.
Old Mar 5, 2007 | 06:55 PM
camarorz28's Avatar
yes thats what i thought thanks, i'll look for some other ones then thanx sellc
Old Mar 5, 2007 | 06:56 PM
95slvrZ28's Avatar
You also need center bolt style. Narrow your search on Summit, you'll be able to find some.
Old Mar 5, 2007 | 11:38 PM
camarorz28's Avatar
ORIGINAL: 95slvrZ28
I did what you said and i went to the Chevy small block Gen II (LT-based engines) and all i find is bolts, i try searching out off Chevy small block Gen II (LT-based engines) and all i find is valve cover that have two wholes on one cover and another whole on the other valve cover. I have not seen that my driver side cover has anything connected to it, another words a whole.
Old Mar 5, 2007 | 11:41 PM
shnormo's Avatar
You can get their valve cover adapters. I personally would go that route.
Old Mar 5, 2007 | 11:42 PM
shnormo's Avatar
Or you could get fabricated ones.
Old Mar 5, 2007 | 11:49 PM
camarorz28's Avatar
i sure dont want to spend a tons of money on them i was willing to pay at least some 80 buxs no more
Old Mar 10, 2007 | 01:08 AM
aap94z's Avatar
well i know this is not the right thing to do but i took some cheepies and carefully tapped them with a small body hammer untill they fit under the alt. you cant see that part anyway and it worked so who cares.
Old Mar 12, 2007 | 04:17 AM
sellc's Avatar
ORIGINAL: aap94z
While I dont share his entusiasum about that method, I will say they sell nice polished aluminum notched center bolt valve covers on E-bay for under $150. They have to be further cut out for roller rockers but fit stock rocker arms without modification. Search "LT1 350 Valve Cover" on e-bay and you should see them.
