How do i replace power steering pump hose.
Old Aug 13, 2012 | 01:16 PM
94ChevyCamaroV6's Avatar
Default How do i replace power steering pump hose.
I have this hose that is leaking pretty bad im not sure how to replace it. Is there a special tool to get the hose off or how do i remove it. Also, i recently installed a egr valve and i noticed that i can see about 1mm between the gasket and the egr valve, is that bad or what would cause the gap.
Old Aug 13, 2012 | 06:37 PM
Massey's Avatar
The only "special" tool needed is a flare nut wrench. I dont know the size as I didnt remove my power steering lines when I replaced Sarah's engine. These wrenches are designed to not round the corners of the attaching nuts. Also you may have to remove the power steering pump to get to the hoses on the back of it.
As for the gap in the EGR, there should not be any gap. Remove it again and make sure everything lines up right and that you didnt get any debris in between the valve and gasket.
Massey
Old Aug 13, 2012 | 09:10 PM
krazy3's Avatar
I was able to change the hose on my 97 RS without any special tools, but it wasn't easy!
Old Aug 13, 2012 | 11:12 PM
I would have to get a new gasket right. Could it be that one side is tighter than the other, but if i go to tighten the other side couldnt it strip the threads.
Old Aug 14, 2012 | 12:55 AM
Massey's Avatar
There is no gasket where the hoses meet with the pump or the rack. The seal is created by the tapers on the devices and hoses.
Massey
Old Aug 14, 2012 | 01:18 AM
I was talking about the egr valve, but what line is this one called so i can get the right replacement hose.
c2stone
May 23, 2011 09:20 AM
91z28slowmaro
May 30, 2009 03:21 PM
therodsite
Dec 12, 2008 08:16 PM
MidnightLS1
LS Series Tech
Oct 6, 2008 08:32 PM
PopCycl
May 17, 2008 10:25 PM
