How do I remove a licnse plte that has no bracket? want to takeoff stack of Reg tags
Old Jan 17, 2024 | 10:26 AM
CamBigCat's Avatar
Default How do I remove a licnse plte that has no bracket? want to takeoff stack of Reg tags
Hello all,
I have no bracket frame or fancy logo around the license plate indentation area
I need to avoid theft as this is a high incidence at the start of the year
I usually vertical slice a registration tag with a utility knife, but there are a stack of old ones on top of each other (make theft of reg tags more favorable to / easier for the bad guys) and to fully access w/ a sharp putty knife, warm water and maybe a hair dryer, I need to remove the old ones in order to satsify my apartment manager's indoor parking rules very soon, so time is of the essence
Is there a bolt behind the 2 flat tip screws?
Or does that just get screwed on tight clockwise into the frame?
*Hopefully, it'll be an easy 1 hand job on both screws
It seems I have the similar plate system like the attached Indiana resident who moved to N. Mexico
Thanks in advance
Old Jan 17, 2024 | 11:12 AM
CamBigCat's Avatar
a ph call w/ 1 of my freelance mechanic friends revealed that there's no back bolt like the square kind u find on an old erector set toy
will keep ya'll advised on progress
of removal and if water and a hair dryer worked as shown in 1 video on yt
it appears a stack of reg stickers on top of each other attracts registration thieves
this sadly is a rampant problem nowadays
Old Jan 17, 2024 | 01:33 PM
CamBigCat's Avatar
It was a lot easier than I thought
After loosening w/ a flathead s driver, I Manually I screwed on the flat head screws which thankfully were not rusted
and as u can see from the pic attached, gorilla glue duct taped it to temporarily fasten it
there is a frame, not a fancy one, but none the less a plastic black thin frame
I applied as pics show, hand sanitizer to loosen the stack from years 2018 to 2024 (6 yrs worth)
and applied a hot blow dryer to loosen
it fell off in 1 fell swoop, just scraping in one direction till ALL the colors representing the different year tags were removed
and then I vertical sliced thru the 5 and zeros
I hope this was helpful
Here's a vid of a fellow Californian who removed a stack of reg tags
tools and residue of the peelings moistened with hand sanitizer / alcohol, reverse side of lic plate and lic plate frame
Old Feb 18, 2024 | 07:31 PM
joelle king's Avatar
Nice videos
jaxZ28
Feb 14, 2012 02:40 PM
g3mini609
Mar 1, 2010 05:12 PM
caddbkj
Dec 14, 2009 09:27 PM
caddbkj
Dec 13, 2009 09:30 AM
HEAVYCHEVYMAYNE.
Dec 6, 2007 09:02 AM
