How do I bleed the clutch system?
I made a post earlier about not being able to shift into reverse, it turns out I cant shift into any gear while its running so I guess I need to bleed the system. I cant reply in the old thread for some reason so I made a new one. Can anyone tell m or link me a guide on doing this? I found one short run through on it and the guy mentions "cracking" the metal line on the slave to allow bleeding but I have no idea what hes talking about. I dont want to just go out there and start bending my lines without knowing what Im doing.
RE: How do I bleed the clutch system?
The term "cracking the line open" doesn't mean to go and bend the line till it breaks. [:@]
What that means is to loosen the fitting to allow air to escape. If you don't have a bleeder valve at the end of a hydraulic line, "cracking it open" at the fitting is the only other way to bleed air out.
Oh, and by the way, that is a term that is used regularly by plumbers.
It also has nothing to do with whether or not their own crack is showing.
