How to check coolant circulation
Old Jul 14, 2009 | 08:34 PM
Racer's Avatar
Default How to check coolant circulation
95 3.4L v6.
Any good way to test to make sure water is circulating? I mean the upper and lower hoses get hot as does the radiator.
I changed the thermostat and when I removed the upper hose and housing, there really was no water in the hose or housing. Replaced everything and filled the radiator and maybe put in 12 ounces of coolant. Something just doesnt seem right to me.
I cant help but think its either a water pump issue or radiator. I would think that when the upper hose is empty and you add coolant it should drain down and fill that hose or am I looking into this way too deep.
The car doesnt over heat, in fact according to the temp gauge, it runs too cool, but if there was no water touching the sensor, it would give a false reading.
Old Jul 14, 2009 | 08:41 PM
Saint_Ali's Avatar
after the car has been running touch the radiator hoses,they should be pressurized and hot to the touch
Old Jul 14, 2009 | 09:07 PM
Racer's Avatar
Well they are hot to the touch, but they do not seem to be stiff, like there is any pressure in them if thats what you mean.
I did remove the belt and I can easily spin the water pump over by hand. Does not appear to be any kind of drag. I would think you should be able to feel some kind of resistance from the coolant?
I mean the pumps are cheap enough and I might just replace. If its not that, then it has to be something in the radiator.
Old Jul 27, 2009 | 03:21 AM
95_V6_Luvr's Avatar
Default Radiator troubles
I am having a similarly related problem. My '95 3.4L V6 is sucking down water and overheating like crazy. But the weird thing is that I dump tons of water into the radiator yet never fills all the way, the water just keeps going down BUT IT DOESN'T LEAK! I'll drive it a bit and it will over heat, then sometimes will drop in temp drastically...HELP!
(should i make my own thread?)
Old Jul 27, 2009 | 03:54 AM
yes please
Old Jul 27, 2009 | 03:59 AM
its not under that much pressure. 14 lbs. your garden hose is probly somewhere over 50lbs. if its not over heating or leaking i dont see a problem unless the hoses look cracked or in need of changing.
Old Jul 27, 2009 | 11:12 AM
You could try to bleed the system. If the system is not creating/holding pressure that is a reason for concern. You can borrow a pressure tester from Autozone and see if the system will hold pressure. If it will not you will have to chase down where the leak is. If it holds pressure with the tester but does not build pressure after 15-20 minutes, replace the rad cap. its the only part for the system the pressure test can not check.
Your system needs pressure to work. Without pressure you can damage head gaskets or even heads.
in 20 years of working on cars i have never seen a water pump that was still sealed and turning that just did not pump water. They are just to basic a system.
Old Jul 27, 2009 | 11:16 AM
Welcome to the "I have a 3.4 with a blown head gasket " club. Its a huge club. Course we need more detail but if the water is not falling out the bottom or going into the oil the only place left is out the tail pipe. It is a known issue with these cars.
Greg08
Oct 4, 2012 09:31 AM
1971BB427
Nov 9, 2011 06:32 PM
Camaro3800V6
Aug 17, 2011 03:47 PM
Rob91
Apr 21, 2011 11:09 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
