how to change coolant.
Old Jun 2, 2012 | 02:58 PM
94ChevyCamaroV6's Avatar
Default how to change coolant.
How much coolant should i get for my 94 camaro. Its a little dirty and for some reason is brown. What should i get a bottle of straight coolant and a gallon of distilled water or what should i get.
Old Jun 2, 2012 | 03:17 PM
you want a 50/50 mix. the cooling system holds about 3 gal dry and a little over 2 gal if your doing a drain and refill. probly be a good idea to do a flush while your at it.
Old Jun 2, 2012 | 03:39 PM
so buy 1.5 gallons straight coolant and 1.5 gallons distilled water? and i have like .2 gallons at home of coolant so if i just bought a gallon and had 1.2 coolant and 1.8 distilled water any ideas on what of a temp that would be good at. I store the car in the winter so i wouldnt want it to freeze. If i should just get the 1.5 and 1.5 i can do that.
Old Jun 2, 2012 | 05:30 PM
copied from here Antifreeze Low Temperature Protection i use the green stuff in all my vehicles.
6. Antifreeze Low Temperature Protection
a. Do not add 100% antifreeze directly to radiator.
b. Use 50/50 Ethylene Glycol antifreeze to protect cooling system for temperatures down to -34° F (-37° C). Use 50/50 Propylene Glycol antifreeze to protect cooling system for temperatures down to -27° F (-33° C). Use 50/50 antifreeze to top off or to refill a cooling system that requires the additional coolant for any reason.
c. Use type 60/40 blend antifreeze to protect cooling system for arctic temperatures. CAUTION Never mix Arctic type antifreeze with water or inhibitor. Always use Arctic type antifreeze full strength. Water can not be mixed with Arctic type antifreeze because water will freeze at 32° F or 0° degrees C.
d. A mixture of 60/40 Arctic type Ethylene Glycol antifreeze will provide freeze protection down to -62° F (-52° C). A mixture of 60/40 Arctic type Propylene Glycol will provide freeze protection down to -56° F (-49° C). Use 60/40 antifreeze to top off or to refill a cooling system that requires the additional coolant for any reason. If antifreeze does not meet the freeze point for Ethylene Glycol or Propylene Glycol, users should replace it with new coolant.
Old Jun 2, 2012 | 11:28 PM
androzer's Avatar
y should I use anti freeze if temperature never go below -5 in my country?
can I just use water with antitrust?
Old Jun 2, 2012 | 11:43 PM
antifreeze has a lubricant in it for the waterpump. soo you would also need to add waterpump lubricant to it or get antirust additive with lubricant in it.
Old Jun 3, 2012 | 12:28 AM
androzer's Avatar
ya thats what I have done used Preston antitrust that support water pump.
u fell the water like oil now.
thx
Old Jun 5, 2012 | 07:16 AM
mezzyshredder's Avatar
Banned
The car was designed to use antifreeze and thats probably your best bet if you want longevity out of your pump.
Old Jun 5, 2012 | 07:51 AM
-5 C = 23 F. That's below freezing, so why wouldn't you want to use an antifreeze? All it takes is one fluke day that drops way low and that could be enough to crack your block.
Old Jun 5, 2012 | 07:52 AM
Camambro's Avatar
April 2012 ROTM
I don't see why you would want to use anything else but it's your car
