How can u make a 93 Camaro drive better in the winter?
Old 11-04-2011, 09:33 PM
libertyforall1776's Avatar
Talking
Start a quiz here on when everyone last changed their brake fluid, and you will quickly find out why it does matter -- because so many people neglect it. You can start -- when was yours last changed?
Originally Posted by shawnathan
It does perform a tiny bit better the only difference is boiling points. And like I said that really only matters in very extreme conditions it's not worth the extra like 3 bucks a container. He has isn't racing it anyway it's his dd. Trust me I know I just took a 1 month class on brakes and got my ase certification.
  #32
Old 11-04-2011, 09:44 PM
77 kencraft's Avatar
I had a 93 z28, Kansas city winters, all weather tires and sand bags helped alot, use the tranny 2nd gear take offs Had a 97 ss just left it ih the garage in weather
  #33
Old 11-04-2011, 09:56 PM
shawnathan's Avatar
3 weeks ago flushed with dot3 and my other car 8 months ago. It should be flushed around every 20k miles that's what I usually do to keep everything clean.
  #34
Old 11-05-2011, 11:10 AM
^ The reasons to go with DOT 4/4.5 are higher performance and especially the higher wet boiling points and the fact that I bet most of the people here haven't flushed their brake fluid in the last two years, and undoubtedly have moisture built-up in their systems...
Moisture in the system has nothing to do with using Dot 3 or Dot 4. You're making it sound like Dot 4 is a cure for fluid moisture. Bleeding the system to get rid of the bad stuff is the cure, not the 3/4 fluid. The difference between the two is the boiling point (284 vs 311 F), which is more important if your car is a road racer. Use either one.
  #35
Old 11-05-2011, 11:38 AM
Wow guys, I never even thought about the need to change brake fluid, guess I better get it in gear, and start. Thanks for the heads up, could save alot future problems.
  #36
Old 11-05-2011, 01:00 PM
3800camaro's Avatar
  #37
Old 11-05-2011, 01:23 PM
Lightbulb
Really? I would think of it as insurance -- if wet fluids can drop the boiling point easily by 100-degrees or more -- it's nice to know that your fluid has some room to give...
Plus your temp numbers are not universal, as many exceed the base specs -- Motul RBF600 fluid is 420 deg F Wet boiling temp:
Strano Performance Parts - Part Details
Castrol SRF is 518 deg F Wet boiling temp:
Yes of course changing the fluid is a great idea at 3 yrs or sooner depending on use...
  #38
Old 11-05-2011, 10:29 PM
shawnathan's Avatar
It's Extreemly unlikely you would get enough water in your system to lower your boiling point that much without noticing an issue. 69 is correct only go to 4 or 4.5 if your racing or living in volcano or antartica.
  #39
Old 11-06-2011, 06:23 PM
^ Choose your own adventure. I will take the extra margin.
  #40
Old 11-06-2011, 08:49 PM
Senshi09's Avatar
you all brought up a interesting topic. Brake fluid... how do I flush my fluid to put fresh in? I can almost guarantee that it has never been done.
Quick Reply: How can u make a 93 Camaro drive better in the winter?
