horrible mileage
Old 01-22-2011, 07:23 PM
im sure it helps otherwise non of the guys would use it. i havent used it. i wanted to know for sure my injectors were working right. where you at ill see if i can find a shop near you.
  #32
Old 01-22-2011, 08:43 PM
auto's Avatar
5 boroughs, nyc
  #33
Old 01-22-2011, 09:19 PM
heres one at 2992 Oakdale Court, Wantagh - (516) 492-6504
http://www.southbayfuelinjectors.com/cleaning.html
  #34
Old 01-22-2011, 09:22 PM
auto's Avatar
man ur good..
  #35
Old 01-22-2011, 09:24 PM
auto's Avatar
hey when i take out the injectors does it matter what order they have to go back in? i mean put it where i took it out?
  #36
Old 01-22-2011, 10:32 PM
no but i kept track to see what individual cylinders were getting.
  #37
Old 01-23-2011, 10:31 AM
Originally Posted by auto
went to my local autozone and asked a couple of the guys what they think the problem is.. funny thing, they said that they have also been getting bad mileage lately and they suspect its the gas we are getting here. they actual words were dont change anything on the car its the gas. so now im at a stand still...
Which is exactly what I told you earlier. Personally, I wouldn't go effing around with any of the engine's mechanicals until spring gets here. Cars do get worse mileage in the winter, it's the nature of the beast. If by then your mileage is still bad, then I would suspect a bad oxy sensor messing up your air/fuel mix more so than it being a fuel injector. What's the theory behind a possible clogged injector causing it to spray more gas anyway?
  #38
Old 01-23-2011, 11:21 AM
auto's Avatar
i dont think its spray more or less gas, but if it sprays in a stream rather than a mist like spray then i think it wastes the gas, not spray more
  #39
Old 01-23-2011, 11:34 AM
at 9 mpg something is not right. i get better than that with the 1ton 4x4.
  #40
Old 01-23-2011, 04:04 PM
Maybe you wouldn't be with New York gas!
Quick Reply: horrible mileage
