Horn
Old Nov 3, 2010 | 10:52 PM
ampprc's Avatar
Default Horn
when i try to hit thorn on the steering wheel it dose not honk. when ever i hit the panic button or hit the lock button twice it will honk. could it be the relay?
Old Nov 4, 2010 | 11:50 AM
check the fuse?
Old Nov 4, 2010 | 12:10 PM
if fuse is good then its either the buttons, bad wire to buttons or the relay. im showing a terminal L=orange wire, terminal m=black wire, terminal n=dark green wire. L is the hot wire and should have power at all times, m is the incoming power from the steering wheel buttons, n is outgoing power to the horns. test for power to L if no power then problem is in the fuse or wiring. if power to L then test m for power when the steering wheel button is pushed, if no power both button switches on steering wheel or wiring to them is bad. if power to m when button pushed then test n for power when the button is pushed, if no power then relay is bad, if power horns or wires to horn are bad.
Old Nov 4, 2010 | 02:12 PM
ampprc's Avatar
thanks for the information.
PCweber
Apr 27, 2012 12:55 PM
brunk5
Oct 22, 2010 11:54 PM
kevink713
May 10, 2008 09:03 AM
Rs Camaro Kid
82-92 V6 Tech
Jul 13, 2007 03:36 PM
hsdragracer
Mar 30, 2007 11:26 AM
