Hood above headlight higher on one side
Old Dec 15, 2013 | 06:03 PM
Dc42361's Avatar
Default Hood above headlight higher on one side
On my fourth gen my hood sits up higher on one side and is noticeably annoying, is this common? And what can I do to solve this problem? Thanks Dustin
Old Dec 15, 2013 | 06:46 PM
there are adjusters on each side. should look like rubber ***** with a place to get a wrench on it under the rubber. are you sure its not a bent hood or fender or front cover is not out of adjustment?
Old Dec 16, 2013 | 09:13 AM
Dc42361's Avatar
the rubber pieces are in the middle front portion of the hood? I really am not sure what cause it I was just looking for a solution. Hahaa
Old Dec 16, 2013 | 11:00 AM
Most of the time it cause by the car hitting something and it is fixed by a body man. I don't think we are going to be able to tell you haw to do body work based on your description.
This could be anything from a slightly tweaked hood to good parts bolted onto a bent chassie.
kuhlman187
Aug 11, 2015 11:02 AM
tjwsc2010
Feb 28, 2010 09:22 AM
JaDARaD8*
Apr 26, 2009 08:11 PM
BAN WS6
Aug 11, 2007 08:25 PM
