hit a curb last nite
Old 09-12-2010, 06:50 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Originally Posted by 92typhoon937
k thanks i know where that is i went to school at vo tech
No prob. I live like 5 minutes away from there, so that was the main reason for going there. Didn't want to risk overheating again and causing even more problems.
Old 09-13-2010, 10:44 AM
Massey's Avatar
I am having cooling problems too and it is about pissing me off, I may be pulling heads [grrr]
OK as for hitting the curb... check out your panhard bar under the car. It is the long bar that goes from the rear end to the passenger's side. It should be U shaped and straight with no bends in it at all. If is bent or the U-channel goes narrower or wider you need to replace it. If you dont your car will run down the road like a dog that is tied to a chain. A bent panhard bar will prevent you from getting a proper alignment. You can get the front end aligned with a 2 way alignment but if you get a 4 way alignment the screen will pop red all over the place. The alignment tech fresh out of high school auto shop will say "sumptins bent...er... " So check everything out and replace anything that is bent before you head out.
Massey
Old 09-13-2010, 11:45 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
i have a double adjustable panhard bar for sale if you need it =]
Old 09-13-2010, 06:18 PM
92typhoon937's Avatar
i'd buy it if it wouldnt cost much to ship
Old 09-13-2010, 06:19 PM
how much u want for it and how much to ship it
nickplee
01-12-2011 07:38 PM
RS96LSU
05-26-2008 04:59 PM
torquer516
11-04-2006 10:04 PM
Quick Reply: hit a curb last nite
