Slid into curb.. Scary! With pics
Old Jan 9, 2011 | 10:39 PM
nickplee's Avatar
Default Slid into curb.. Scary! With pics
On my way home today (doing about 30mph) I skidded and did a 180. I wound up hitting the curb on the other side of the road and damaged my wheels. The car is fine.
The passenger rear tire/wheel seemed to get the most force, but I will need to replace both the front and back passenger rims, and probably the tires too. Anyone ever do this in the past? How durable are the suspension components/rear axle? I ordered two replacement rims tonight on eBay, thankfully they aren't that expensive.
Old Jan 9, 2011 | 10:44 PM
Buffalo02Z28's Avatar
I've done it before. I felt like an idiot after. I cracked two wheels and offset my rear end. All I needed to realign the rear end was an adjustable panhard bar.
Old Jan 9, 2011 | 11:07 PM
Massey's Avatar
Well I took a direct hit on the front wheel when I got T-boned and it took out the spindle and upper arm. I got hit pretty high compaired to your hit. My lower arm took the hit pretty good but you could see where the bushing caused a little damage. My lower arm still measured out the same as the passenger's side did so I reused it. As for the rear your panhard arm prolly is toast and a new one is needed. They are the same from 82-02 but I would try to get the newest one you can, or a stronger aftermarket one from BMR or UMI. Once the bar gets replaced make sure you get an 4 way thrust alignment. They cost a little more but will let you know if you have anything else bent.
On and you may have a bent axle as well. My friend had a spring perch break and it spun his Z28 around and tagged a curb bending the axle.
Massey
Old Jan 9, 2011 | 11:23 PM
Mikey.'s Avatar
That sucks man. Could have been worse though. You could have had some c5 rims instead of those salad shooters.
Old Jan 10, 2011 | 12:31 AM
BasicConcepts's Avatar
Technical User
should get some c5 rims instead or replacing those shooters i found a set on craigslist about a week ago with good rubber for 400
Old Jan 10, 2011 | 12:55 AM
There's full set of wheels straight off of a C6 Corvette in my area for $375.
Old Jan 10, 2011 | 01:08 AM
Mikey.'s Avatar
Wish they had those in NC.
Everyone wants like 650-900 here.
Old Jan 10, 2011 | 10:08 AM
Technical User
your about an hr and a half from these beauties
there replicas but have nice rubber
http://greenville.craigslist.org/pts/2144908513.html
Old Jan 10, 2011 | 10:46 AM
rmoncur's Avatar
Some pretty skinny rubber for such a wide rim...but they do look nice
Old Jan 10, 2011 | 10:47 AM
RFxCamaro's Avatar
DAMN I dont know what is better the rims of the location. This is SPARTANBURG!
