hid headlights and fog lights
Old 02-16-2012, 11:33 AM
androzer's Avatar
Make the most durable thing. u know putting the epoxy and removing th bulbe every once and while might brake the glass of the sealed beam. so start with fog lights and apply ?HID
kit, cause police might stop you if ur low beam is not working, and by the way HID those who comes with Ballast are so fragile and sensitive.
Old 02-16-2012, 11:37 AM
iLL95's Avatar
I Like to Party
Super Member
Originally Posted by BM-Z28KING12
Yea considered that so I was thinking about getting a cheap set from ebay to see if they are going to work and also running a relay for them to see if that makes a difference
Don't do this, I tried that with Xentec and got a faulty balast as soon as I recieved the order. You might also get the dreaded flickering with cheaper HID kits. I recommend DDM Tuning : HID Kits Their HID kits are flawless and they have a warranty. For 4th gen camaros; the hid bulb size for low beams are 9006 and 9005 for high beams.For fog lights its 885. If your car is burning through regular bulbs I recommend cleaning your negative connections and running some tests with a voltage meter.
I plan on putting H3 HID kits in my modded angel eyes
Check out this video
1996 CAMARO HID HEAD LIGHTS AND LED TAIL LIGHTS ! - YouTube
Hehe, I'm Skittlesking with the top comment
Old 02-16-2012, 12:24 PM
BM-Z28KING12's Avatar
Thank you this is very helpful I've been looking and have been referred to ddmtuning before so I will probably go with that.. im not so sure how I feel about the angel eyes but I like to switch things up every once in a while. What brand are you using for those and do you have a link for them
Old 02-16-2012, 01:05 PM
iLL95's Avatar
I Like to Party
Super Member
There was an old write up on it but heres one I did(the original writeup is in there): https://camaroforums.com/forum/4th-g...93-97-a-66013/
Hope it helps
Old 02-16-2012, 01:46 PM
i got into a batch of bad bulbs a couple years ago and went through quite a few before i got into some good ones. dang things are not cheap. i have some sylvania h4351 xtravision for low beams and eiko 65w h4352 high beams waiting for the stock ones to burn out.
pojo1988
08-27-2017 09:35 PM
67Harbor
10-07-2013 06:38 PM
98Z28ImportSlayer
03-16-2012 09:07 AM
vXIcetreyXv
10-23-2009 07:25 PM
91 RS
02-24-2007 11:14 PM
Quick Reply: hid headlights and fog lights
