HELP rear end leak
Old Dec 23, 2011 | 11:09 AM
98stuntin's Avatar
Hopefully you made some reference point mark with the pinion nut before you removed it, so you can get it back exactly where it was. Otherwise you're looking at a possible premature ring & pinion gear failure down the road.
i did not is there anyway i can fix it?
Old Dec 23, 2011 | 11:34 AM
There's not an "easy" way now any more, you lost your reference point. All you can do is keep your fingers crossed and hope you didn't mess up your pinion gear depth. Sometimes guys get lucky, sometimes not. Keep an ear on the rear when you drive. If it ever starts to sing, it won't be a happy tune.
Old Dec 23, 2011 | 12:34 PM
Failed Devices's Avatar
I ran into the same issue on my truck, changed the pinion seal but didnt mark it up correctly. Just make sure the pinion nut is torqued to spec, and thats about all you can do at this point.
Mikeroc283
82-92 V8 Tech
May 12, 2014 09:30 PM
typeomang
Nov 21, 2009 08:37 AM
Chia219
70-81 V8 Tech
Sep 7, 2009 06:42 PM
dangarsan
Nov 1, 2008 07:15 PM
sewerrat
Apr 19, 2008 08:06 PM
