rear mail oil leak
Old Nov 1, 2008 | 06:14 AM
dangarsan's Avatar
Default rear mail oil leak
4th generation v6 215000 miles ,is it worth replacing rear crank seal? mechnic there may be too much play, would not seal, need to know if its worth a try
Old Nov 1, 2008 | 07:46 AM
blackz87's Avatar
Default RE: rear mail oil leak
If it is just small drops and not a major oilleak , I would leave it alone.
Old Nov 1, 2008 | 07:15 PM
MadMikeZ28's Avatar
If there is too much play then maybe it needs the thrust bearing replaced. With the transmission out to do the rear seal the bearings can be replaced while the engine is still in the car.
Are you sure it is the main seal? On the 60 degree V6 there may be a bolt on plate with a gasket for the cam instead of a plug. Those gaskets are good for leaking.
Mikeroc283
82-92 V8 Tech
May 12, 2014 09:30 PM
98stuntin
Dec 23, 2011 12:34 PM
typeomang
Nov 21, 2009 08:37 AM
Chia219
70-81 V8 Tech
Sep 7, 2009 06:42 PM
sewerrat
Apr 19, 2008 08:06 PM
