Help please! Broken window regulator rivets
Old 12-20-2011 | 02:40 PM
vanquishfist's Avatar
Default Help please! Broken window regulator rivets
I am in the middle of changing my driver window motor and found I have two broken rivets. How do you think I should go about repairing this? Picture shows which ones are bad. I have the old motor out now.
Attached Thumbnails Help please! Broken window regulator rivets-1220011316.jpg
Old 12-20-2011 | 02:56 PM
Drill or knock out the part of the rivet that's still in the regulator, and use screws with lock nuts to reattach to the door.
Old 12-20-2011 | 10:06 PM
torque_is_good's Avatar
yup
on my 4th gen screws and lock nuts were needed
on the 3rd gen I used rivets
Old 12-20-2011 | 10:37 PM
I figured... those were some hard rivets to drill through.
Old 12-20-2011 | 10:42 PM
tt383lt1's Avatar
they do make rivits that big but you need a bigger rivit gun then normal but there the same metal as regulater rivits.
burning camaro
08-09-2011 07:57 AM
Kamaaina64
02-19-2011 08:13 PM
MartineZ28
06-18-2010 11:12 PM
TBenner80Z28
03-29-2010 08:53 AM
98sleeper
03-25-2008 01:00 AM
Quick Reply: Help please! Broken window regulator rivets
