Help please
Old Jul 26, 2022 | 06:10 PM
Joeburnx's Avatar
Default Help please
Help please!!!! I have a 94 z28 Camaro and it’s been giving me nothing but issues after I changed a few things on the car. I’ve changed the radio, the two front door speakers, k&n cold air intake, and a new mass air flow sensor. The car had been stalling on me after driving it for little bit and it would just straight up die and cut off all power while driving. It would start back up and run perfectly fine for the rest of the drive, but after driving it like that for a couple of days when the car would die, it seemed to be getting worse with starting after the car had died. So I let it sit for while cause I didn’t have time to work on it or look at it but I’ve recently just removed the radio, door speakers, unplugged the air pump cause it kept blowing the fuse, and put in a new MAF. Started it up and the fans turned right on along with engine light. It’s never done this before other then when I tried to jump the a and b on the obd1 port to read the engine code. So at this point I’m assuming that’s there’s an issue with the fans.
Old Jul 26, 2022 | 06:20 PM
How many miles on the car and do you know if the Optispark has ever been replaced?
The '93 I had also acted like that when the alternator was going bad,drove me nuts wondering what it was then one day it quit charging altogether and died.
Replaced the alternator and no more issues,I had already done the Opti.
Old Jul 26, 2022 | 06:41 PM
Joeburnx's Avatar
The cars got around 137,000 on it but the guy I bought it off a few months ago said he completely redid the ignition system
car also runs beautiful when it runs
Old Jul 30, 2022 | 10:18 PM
may be the ignition control module is unhappy.
Old Jul 30, 2022 | 10:25 PM
also you can not flash a 94. have to use scanner and some will not work on the 94.
Old Aug 5, 2022 | 09:15 PM
MKCoconuts's Avatar
If the SES light is on, it is normal for the fans to kick on, regardless of what code it has. It's a engine protection feature.
Was there a reason you changed the MAF as you said you changed it and then the car started acting up. I'd throw the old on back in and see what happens. Might have a bad new one or you may have bumped a wire or one is loose.
brandonruiz90
Oct 20, 2015 09:10 PM
2Z's
Jun 13, 2014 07:32 PM
bluesmoke662
82-92 V8 Tech
Aug 7, 2011 08:09 AM
92RS FTW
82-92 V8 Tech
11
Apr 9, 2011 01:55 PM
psienide
May 16, 2009 09:28 AM
