Help identifying a part
![](https://cimg8.ibsrv.net/gimg/camaroforums.com-vbulletin/2000x1504/a6861326_a143_4bad_9ed7_46ea400f8cd3_ee58db0cb979de322dd0bc78be51585dea338f44.jpeg)
That metal pipe that the marker is touching is attached at the front of my motor block. The coolant runs through it into my motor block and the pipes branching off go up to my carburetor. The weld broke by the mount and now it’s leaking like crazy. I can’t find the name of the part to order a replacement and I’ve gone over a few diagrams and can’t find a name any help would be amazing. 1994 v6 3.4L I believe
The GM Parts Manual refers to it as a heater pipe for the throttle body. Part number is 10189204 and is still available from GM by special order. Check the attached illustration to make sure we're talking about the same part.
Thanks a million my man that is definitely my part!!! Where do you think would be the fastes way of getting it. The cars my daily driver and it being out of commission is rough to say the least
