1997 30th z28 350/ 6 speed
Old Jul 26, 2019 | 08:30 PM
TRCHARGER66's Avatar
Default 1997 30th z28 350/ 6 speed
Hi everyone, I just had the omni spark replaced in my Camaro and now when you punch it the engine revs to about 3500-4000 rpm and then stalls for a fraction of a second and then catches and continues to climb and then I shift.The mechanic said he does not know what is the reason for it. I am hoping some one here might be able to help me. I have this 1997 Camaro 30 th annv. z28 convertible w/lt1&6spd and a 1991 Camaro z28 w/ 350 & auto w/ T-tops. Thanks TRCHARGER66
Old Jul 27, 2019 | 06:00 AM
Welcome aboard,not sure what the problem is. Does it do this every time or just occasionally?
Did you also replace the plugwires with the new optispark?
Old Jul 29, 2019 | 04:23 PM
Hi yes it seems to happen every time. I pull to a stop and make a turn and accelerate to speed of traffic and it will cut out, like a rev limiter but then catches and climbs. The mechanic replaced the spark plugs and wires and the I c m but not the coil. Thanks for any help
Old Jul 29, 2019 | 09:37 PM
The '93 Z28 I had acted like that after a new opti and plugs/wires,turned out to be a burnt plug wire on #8. Not much room in there,if the wire isn't just right it gets burnt pretty quick. Might not be your problem but worth looking into.
samkopyna
Sep 5, 2012 10:41 AM
octain01
Nov 19, 2009 10:32 PM
domo556
Oct 13, 2008 06:34 PM
1994z28
Dec 16, 2007 03:56 AM
Billy
Jul 17, 2007 10:26 PM
