Help! Coolant leak!
Old 09-20-2012, 12:10 PM
djsquare1's Avatar
Originally Posted by craby
yep new pump should do it. theres a weep hole at the shaft housing and thats where the coolant comes out if the seal fails. make sure the crank sensor connections are dry and while your at it put some electrical grease on connecters.
Thx craby, will do!!
  #22
Old 09-20-2012, 10:39 PM
did you use the forum discount? far as i know still get one from rock, ill have to look.
  #23
Old 09-21-2012, 12:42 AM
BasicConcepts's Avatar
Technical User
it ended at the beginning of the month, it was 5%. there might be another one tho?
  #24
Old 09-21-2012, 08:08 AM
Too late now if he didn't use it, but you have till October 6: https://camaroforums.com/forum/vendo...-2012-a-70576/
  #25
Old 09-21-2012, 02:43 PM
djsquare1's Avatar
I ordered it already
But I will keep this noted as I need 02 sensors!
Thanks!
  #26
Old 09-21-2012, 03:00 PM
It's almost worth it to make up something to order, just so you can say you saved 5%.
You guys gotta pay more attention around here.
  #27
Old 09-21-2012, 04:47 PM
Greg08's Avatar
yes. use RTV on each side of the gasket
  #28
Old 10-02-2012, 11:21 AM
djsquare1's Avatar
Replaced the water pump, and no more leaks!
derrickdiggler
11-15-2011 09:09 PM
mccoyj91
03-10-2010 08:35 PM
VTXed
11-25-2006 12:04 AM
terelk
05-31-2006 04:18 PM
akohnz
05-22-2006 06:58 PM
Quick Reply: Help! Coolant leak!
