help, can i put a olds 455 in 94 camaro??
Old Mar 16, 2009 | 11:47 PM
maxcarparts's Avatar
Default help, can i put a olds 455 in 94 camaro??
recently purchased a 1994 camaro v6 car less eng and trans. struts and cross member have been switched out already but my concern is in the wiring...will a 1972 olds 455 rocket fit and work??
Old Mar 16, 2009 | 11:53 PM
Saint_Ali's Avatar
not without extensive modification to the engine bay....
Old Mar 17, 2009 | 08:00 AM
whammer3024's Avatar
ROTM Winner
sure it can fit...get rid of pretty much every luxury, cut into the firewall and fenders a lot, and get creative..yeah it can be done...however i wouldn't do it
Old Mar 17, 2009 | 04:42 PM
6v49der's Avatar
Do you have a welder?
Old Mar 17, 2009 | 07:22 PM
LOL, Go to a car lot and find a V-8 Camaro pop the hood. Now look at all the brackets, mounts. Everything that bolts onto the motor and the exhaust system. Those are all the parts you will have to make. Not buy, make cause they do not exist. You might as well try to put a ford 429 in there, it would be the same amount of work. The cost would be 10 times what the car would be worth when you where done. To even convert the car over to the V-8 that came in it that year you would need a doner car.
Go find a 3rd gen body then all you will need to do is make motor mounts and the exhaust system. These news cars everything is shoe horned in. Even the 3rd get can me tight with space around the tranny.
Old Mar 18, 2009 | 07:23 PM
thanks all for the heads up....i will now remove head from ars and find a better project...
Old Mar 19, 2009 | 04:08 AM
cbr600rx7's Avatar
If you have that 455 laying around i may be interested for a project i am working on
blackbetty88
82-92 V8 Tech
Feb 28, 2011 04:59 PM
Hotrod688
Dec 23, 2008 02:55 PM
mdmppbog1189
Jun 28, 2006 03:43 AM
