help on camaro
Old Oct 5, 2011 | 08:06 PM
gofastturnleft70's Avatar
Default help on camaro
i dont know much about them other than i use to have a 99 camaro when i was young and insurance was almost 500 a month. anyways i have got a wild hair and decided to buy a 95 camaro with a automatic trans that dont run my question is since a motor change might be step 1 can you put a 5 speed in it without much trouble? and if so what year models could i get one from to fit the 95 camaro thanks guys i have not got the car yet but was just wanting to ask this question as it might decide weather i buy it to start a project thanks and it has a 3.4
Old Oct 5, 2011 | 11:31 PM
MKCoconuts's Avatar
As far as how much trouble it'd be to do the swap, I wouldn't know. As for what years, anything 93-96 will work. If it's a 96 though, make sure it's a the 3.4 and not the 3.8. 96 California Camaros came with the 3.8 to meet emissions and the 3.8 is a 90 degree angled V instead of a 60 degree like the 3.4s.
Old Oct 5, 2011 | 11:50 PM
RFxCamaro's Avatar
95 was the 3.8 cali cars. All 96s are 3.8s or lt1
Old Oct 6, 2011 | 12:01 AM
MKCoconuts's Avatar
You're right. Not sure why I was thinking 96 was starting for 3.8s.
Old Oct 6, 2011 | 12:24 AM
you will need the wiring harness under hood and maybe under dash. you will also need the computer for a 5 speed. it is a major job to switch the trans type or motor type in the 4th gen camaro.
Old Oct 6, 2011 | 07:28 AM
3800camaro's Avatar
Plus trying to find a tranny to fit the 3.4 isn't very easy. There's a few differences in the tranny between 3.4 and 3.8 that makes them engine speciffic.
Old Oct 6, 2011 | 07:46 PM
Specialist's Avatar
damn that bad news for me, b/c i wanted to swap my 01's auto to a manual, i dont want to buy another car because ive put so much time and money into this one
Old Oct 7, 2011 | 09:27 PM
thanks got the car today bought it as not running because when u switch the key it dont do anything when i got home i switched it all the way back then back to run and it started right up anyone ever had this happen looks like it might need a new ignition switch but it starts right up now every time
Old Oct 7, 2011 | 10:11 PM
3800camaro's Avatar
You'll be fine as there's alot of 3.8 trannys out there. Ita just the 3.4 that is impossible to find a tranny for.
Old Oct 8, 2011 | 12:56 PM
Jus22tin's Avatar
wow, sounds like you got a deal. How much did you give for the car? If you don't mind me asking.
