Help with 94 z28 6sp
Hey im new to this but i really want to do stuff to my 94 z28 so i need guidence lol. right now im debating on weather to do a supercharer or a turbo. what should i do and how? do i need a new computer chip also? any tips would be great!
Before you go digging into putting boost on your car, do some other bolt on mods first.
Headers
High-Flow Catalytic Converter
Cat-Back Exhaust
Cold Air Intake
3.73 or 4.10 Gears
Performance Clutch
Short Shifter
SS Sway Bars (Front and Back)
Stiffer Lowering Springs (Front and Back)
I would dig into doing those things first. Then if you still want more ponies, look at a Supercharger
Good luck and welcome aboard the forum!
Headers
Cat-Back Exhaust
Cold Air Intake
3.73 or 4.10 Gears
Performance Clutch
Short Shifter
i think ive seen some plus rebuilding and all would require very deep pockets im just a college kid doing little at a time with my paycheck each month lol
This will give you a general idea. There are cheaper parts out there. Some of these things, such as the cat-back exhaust, you can get used for $100 if you look around. Craigslist is your best friend on anything like this. Except the clutch and lowering springs. You will want to get those brand new.
Headers
http://www.summitracing.com/parts/PSM-70-2239/
http://www.summitracing.com/parts/MPE-36009/
Cat-Back Exhaust
http://www.summitracing.com/parts/MPE-15620/
Cold Air Intake
http://www.summitracing.com/parts/SLE-21014/
3.73 or 4.10 Gears
Best if you can find a whole rear end. Craigslist.com is a winner for this
Performance Clutch
http://www.summitracing.com/parts/ZZZ-HP70043-1/
Short Shifter
http://www.summitracing.com/parts/HUU-3915061/
Once again, Craigslist.com is the winner for these parts
http://www.summitracing.com/parts/SLE-70009/
Headers
Cat-Back Exhaust
Cold Air Intake
3.73 or 4.10 Gears
Performance Clutch
Short Shifter
i moved your thread to the 4th gen section. please read the site rules. also look the stickies over at the top of the sections, lots of info for you there. its real easy to pop 6k into a motor without boost. to do a motor with charger you will want to build the lower end to be compatible and stong enough so your lookin at more coin to do that.
thanks fro moving my thing to the 4th gen section i still dont no what im doing on this yet. and thanks for the list of parts i think im ging to get those but i already have a dule tip squar exhaust so i can mark that of the list lol
