Help! 1998 Z28 Brake Caliper Bracket - What Interchanges?
Old Jul 17, 2010 | 06:09 PM
The Corvette Doctor's Avatar
Default Help! 1998 Z28 Brake Caliper Bracket - What Interchanges?
I broke a bracket tonight and I have to be on the road tomorrow to be at work Monday. I can't get one locally but a guy 100 miles away is parting a '96 Z28. I'm betting the brackets are not the same, are they? Anyone know?
Here is the '98 caliper bracket.
Old Jul 17, 2010 | 11:38 PM
I managed to drill out the broken pin in the lower hole of the bracket and going to pick up new pins tomorrow. If you haven't greased your pins, you should consider pulling the wheels, then the calipers, and grease those pins just to be sure they are free and not getting hung up.
Otherwise, have a drill press and lots of patience.
The pins are a set of four for $25 from Advanced Auto.
The brackets I found were only special order and then the store couldn't find them to order.
mab6680
Mar 10, 2014 07:49 AM
socalrs
Feb 6, 2012 04:55 PM
Pemolis
Sep 23, 2011 04:30 PM
350rs
Jun 1, 2009 05:26 PM
kaoss_11
Mar 7, 2008 10:44 AM
