Heater hoses
Old Dec 27, 2017 | 02:27 PM
Rj165110's Avatar
Default Heater hoses
I have replaced my heater core and still don’t think I’m getting flow so I think my hoses are clogged. I can’t find the entire heater hose assembly. So should I just run 3/4 and 5/8 heater hose from the pump and motor to the heater core? If so how are you guys routing them? I tried removing the hoses and forcing water through them but it won’t go through. It is a 95 with a 3.4L
Old Dec 28, 2017 | 06:52 AM
there is a flow restrictor in the return side hose, its a disk with a small hole in it to slow the flow of coolant so heat transfers better. i would suspect its plugged. did you try running water pressure both directions?
Old Dec 28, 2017 | 07:00 AM
i am finding new heater hose assemblies for 3.8 and 5.7 buy not for 3.4. i am not sure if they are different. https://www.bing.com/images/search?v...3.4&ajaxhist=0
Old Dec 28, 2017 | 07:02 AM
also have a look here 4th Gen LT1 F-body Heater Hose R&R
Old Dec 28, 2017 | 08:03 AM
Rj165110's Avatar
I will try to flush it better and see if that helps. I will also look at these links. Thank you very much.
kyleb
Feb 7, 2008 11:59 PM
sl1foru
Jan 16, 2008 02:16 PM
dhighway
Jan 12, 2008 07:28 PM
kyleb
Dec 15, 2007 11:59 PM
camarohelp
Dec 29, 2006 08:10 PM
