heat works when it wants to?
Old Jan 25, 2011 | 04:58 PM
sebi1990's Avatar
so i poured a whole gallon of coolant in the car and now the heat works fine as well as it done not overheat is there any way that my car can be eating away on the coolant?
Old Jan 25, 2011 | 05:06 PM
Massey's Avatar
yup in many ways. First is from a bad head gasket. These can cause water to be "burnt". Next place that is common with the 3.8L is the lower intake gasket, which can leak water into the oil (bad) or onto the ground (not as bad). If you go to Autozone you can borrow a coolant system pressure tester and see if you have a leak somewhere.
Massey
Old Jan 25, 2011 | 08:57 PM
sebi1990's Avatar
ok so when i get the coolant system pressure tester how do i work it, am i going to have to do it myself or are they going to do it for me? If i have to do it myself can you guide me through the process?
sebi1990's Avatar
Also what is the worst thing that can be happening as of right now?
Old Jan 25, 2011 | 09:11 PM
sebi1990's Avatar
I've noticed my engine overheating so I visited the local autozone and got a whole bottle of coolant fluid and poured it all in now its still there but a significant part of it is missing i made about 20 miles.
Old Jan 25, 2011 | 09:47 PM
can you see it leaking anywhere? did you put it in the radiator or the coolant resevor? you need to fill it all the way, put the pressure tester cap in place of your radiator cap, pump the system up to say 14 lbs, is it dropping? if so look for the leak, if not let it set for 20 minutes, has it dropped, if so look for the leak, also look for coolant on the floor/pavement. if its going to the outside the motor it will leave a trail, just gota find it. if its goin into the oil you should be seeing it now on the dip stick. oil turns a yuky milky color.
Old Jan 26, 2011 | 11:01 AM
sebi1990's Avatar
I think i put it all in the coolant resevor it was a black tube on the passanger side of the car i tilled it up till the end and now the level gradualy droped and i did not see anything unusual on the dipstick
Old Jan 26, 2011 | 11:08 AM
when motor is cool open the radiator cap and see where the level is in there. do not fill the reservor all the way there is a indicator for it hanging on the cap.
Old Jan 26, 2011 | 11:32 AM
sebi1990's Avatar
ok what should i will do that and let you know what I've found out.
Old Jan 26, 2011 | 07:18 PM
  #20
sebi1990's Avatar
I've checked the cooland and eveything looks good.
I've also poured it to the black thing on the left that you see in the picture below.
