Headers RED hot
Old Jul 22, 2008 | 07:39 PM
94z's Avatar
94z
Default Headers RED hot
I just got done doing a cam/head/rocker/spings/head install and started it tonight. Whent well for about 3 minutes and then i noticed the driver side header was glowing hot. Im thinking maybe a exhaust valve is staying open? what do you guys think.
Old Jul 22, 2008 | 08:01 PM
camaro_burns_all's Avatar
VIP member
Default RE: Headers RED hot
Well usually that happens after installing a new cams or headers, you have to break it in. You need air to flow through your headers.
If it still continues, the you need to check if your engine is running lean, or the ignition timing is not late.
And the btw my honda has 1.7 litres
Old Jul 23, 2008 | 10:44 AM
viciouZ's Avatar
Check fuel trim on the respective bank. Could be running lean.
Old Jul 23, 2008 | 05:51 PM
94z's Avatar
94z
ORIGINAL: viciouZ
How do i check fuel trim? It is only out of the #5 exhaust port that it glows.
Old Jul 23, 2008 | 08:02 PM
kaoss_11's Avatar
post pics
Old Jul 23, 2008 | 09:40 PM
02StanGT's Avatar
You check fuel trims with a scanner or data logger.
Old Jul 24, 2008 | 05:14 AM
red star's Avatar
Im almost 100% sire its timing. Its so far one way (i wont remember what way) that it spits unspent or still burning fuel out. It happened to my dad, changed the timing and that was it.
Old Jul 24, 2008 | 10:34 AM
94z's Avatar
94z
ORIGINAL: red star
It starteda little hard too and i suspected timing, I thought ti was suppose to set the timing itself? When i put it back togeather i made sure i had both dots on the gears at 6' and 12'o'clock
primo_1976lt
70-81 V8 Tech
Sep 2, 2010 01:52 PM
broncojr_8907
Jun 19, 2010 03:48 AM
sPaC31
Jan 14, 2008 06:43 PM
myTreadZz
Oct 31, 2007 10:24 PM
2fast4u
Jun 4, 2007 08:34 PM
