Header + engine problems 95z28
Old Sep 30, 2008 | 11:17 AM
Bigsexy5.7's Avatar
Default Header + engine problems 95z28
Hey i need some advice regarding my headers because I dont know too much about z28 engines. All of the following were installed by previous owner:
borla catback
headers (unknown brand, they have been manually drilled/toned down to increase performance)
camshaft
rollers
other general stuff
So I payed about $1000 to get it fixed for rear main seal oil leak and some other minor things recently. I drove it around that night and next morning, it barely started, after 1min it started to smoke up a bit from underneath, and after i pulled it out i saw oil leaks at different points on the ground (multiple sources?). While I drove it that night the check engine light came on frequently and everytime it did, it would sound/feel like it was gonna die when idling. Also, at high revs, sometimes the power would give out and there would be a very loud noise coming from before the exit of the exhaust (headers leaking?).
My mechanic first said I would need new headers soon, but now he says I can keep them and replace whatever holds them in place because apparently whatever is holding them in place is worn down extremely (cylinder heads i think he called them). He said labor alone is $800 for cylinder heads...im wondering whether or not he is lying/taking advantage, and what options I have at this point.
Any help appreciated guys
Old Sep 30, 2008 | 04:34 PM
02StanGT's Avatar
Default RE: Header + engine problems 95z28
Find a new mechanic.
Old Oct 1, 2008 | 12:46 AM
95slvrZ28's Avatar
LOL Cylinder heads are worn down.
Take the car to someone else, if that is in fact what the guy told you he's full of BS.
jjc1800
Jun 24, 2011 02:47 AM
BLKOUT
Oct 19, 2010 04:14 PM
uestraven
70-81 V8 Tech
Oct 7, 2009 11:33 PM
Deagle85
Jun 12, 2007 07:11 PM
thebandit110
Feb 2, 2007 02:45 AM
