HAVING PROBLEMS NEED HELP
Old Aug 14, 2008 | 06:31 PM
95slvrZ28's Avatar
Default RE: HAVING PROBLEMS NEED HELP
ORIGINAL: Spartan66
Switching oils wont fix the problem... you want to fix the problem completelyinstead of looking for the quick fix. That quick fix could just cover up the damage or cause the damage to come on at a slower pace meaning you would only be messing up your engine without outstanding signs.
An oil leak isn't usually a motor threatening problem unless you let it go unchecked. That being said some cars when switched over to synthetic from regular oil will start to burn oil or will develop more leaks. Running a regular oil is not going to damage anything, you just have to change it more often. I've seen cars that burn oil (blow by from the rings) with one brand and another brand (same weight, same type) the car won't burn oil, or it wont' burn as much. Often times when you switch the type of oil you're using you'll start to burn oil.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
