Hard start
Hard start
A few days ago driving in a parking lot car died, took several seconds and attempts to start, it did start, however ses light is on now and my tach quit working. After the car restarted ran poorly, was missing, poor performance overall, so after some research and had car on a high end shop obd scanner, and was told fuel trims were all good, so no injector problems, he checked my fuel pressure regulator and said it was bad on top of him thinking opti, so i changed the regulator, and while i had the cold air intake taken off i cleaned the MAF, the air filter, just general clean up, checked all the connections, everything appears to be in good condition...still hard start but car did run better, still missing but only barely, still ses light. So i decided to change the icm and coil, cleaned the hell out of everything made sure grounds were all good, car already has brand new msd wires, and good plugs...still hard start and ses light, the car is running much better, and after it starts, i can turn it off and it will start right up, but only immediately, so really the question is...do you think its this dreaded opti, its fairly new. And its a job that i am not ready for so before i spend the money see what anyone thinks, and the rpm gauge issue i have received pretty vague answers on.
Hey,what are we working on? I guess a '93-'97 Z since you asked about the Opti but they aren't all exactly the same so what year?
If that Opti is anything besides a GM Performance it is suspect,I had a new one from World Products fail in less than 10K miles.
Yeah its a 97 z, and the guy i got it from said it was a cheap one. I am really guessing its the opti, i noticed today in od instead of drive, at low rpms its kinda chugs, my 95 kinda did that as well. The rpm guage died at the same time the ses light came on, and noticed tonight half of the dash lights are out, but temp and oil pressure gauges are working.
Stovetop535
10-31-2013 12:41 PM
