H pipe or straight pipe?
well im gonna run some pacesetter headers on my 95 Z and i was wondering whats better to run a H pipe setup or a straight pipe. Im looking to get the most possible gain in horse power.
If you're looking for the most gain, I think you should also be considering brands like ARH, Kooks... They have features that Pacesetter lacks.
ok I see i was just curious because my buddy has a iroc z with a 350 and he is running an H pipe setup he told me it allows balance in the cars headers because its a V-8 or something like that correct me if im wrong im still learning alot
I think he is trying to talk about exhaust scavenging, which is increased with an X or H pipe. Exhaust scavenging is basically when the low pressure exhaust gases create a sort of vaccumm which helps clear the cylinders and exhaust primaries of all exhaust gases
A V8 fires 2 cylinders in each bank in sequence. If using a full dual exhaust, there will be a momentary increase in back pressure on one side of the exhaust system when the two cylinders fire. The H pipe allows the pressure to be more evenly distributed between the exhaust pipes. This generates a little more power at low RPM, but does nothing much at high RPM. An X pipe is a better way to go as it shows a power increase throughout the RPM range. A properly sized single pipe accomplishes practically the same results, and is a simpler way to go.
thanks I understand now so based on this I suppose a X pipe is the best setup for HP gain thanks guys
