grinding from short throw?
I just put in a B&M yesterday and like ill be in gear and while acceletating if you listen close enough it kidna soudns liek a very quiet grinding sound and this sometimes comes also when you just start pushing the clutch in...
did i do something wrong when putting it in?
RE: grinding from short throw?
Most aftermarket short throws have adjustable stop screws, so when you slam it into gear, you don't break anything. Should be at the front and back of the base of the shifter.
