Governed LT1 ?!
Old 05-25-2010, 08:18 PM
Grandpaswagon's Avatar
It sounds like some sort of tranny issue. Does it shift into 4th during normal driving?
Old 05-25-2010, 09:20 PM
timmyz28's Avatar
nope, i have codes for egr and o2. and yes it does shift into 4th during normal driving. at wot, it doesnt
Old 05-25-2010, 10:02 PM
check the sticky by pete in the trans section see if its covered there.
Old 05-25-2010, 11:11 PM
Massey's Avatar
If you are hitting 115 in 3rd at 5K rpm then you are about at the limit of the engine's computer. The trans not making 4th is keeping you from going faster. Did you get all the plugs plugged back in when you put the new engine in the car? This could be a simple matter of the car just not knowing it can shift again. Also are you driving in D? I know the gear select in the car prolly shows on OD but the tranny may not be in OD. Check the linkage and make sure it is in the proper location. I would be looking into a tranny issue instead of an engine issue. I hope this helps
Massey
Old 05-26-2010, 02:49 AM
timmyz28's Avatar
i checked the linkage and made sure the shift indicator is lined up, and it is. i tried it going down the street, and its fine. as for the plugs, i will check those tmrw. i didnt think of that
Old 05-26-2010, 10:52 AM
Does the trans shift into 4th if you don't have your heel to the steel?
Old 05-26-2010, 03:14 PM
timmyz28's Avatar
Yeah under normal conditions in OD, it shifts perfectly fine
Old 05-26-2010, 03:50 PM
So then, is it correct to say that the trans shifted fine before the engine change?
I'm leaning toward checking the shift linkage too, as Massey suggested. It's possible something got tweaked in the process. Get the front of the car in the air and block the rear tires. From inside the car, put the trans in "D", get under the car and disconnect the cable from the trans linkage arm, and make sure the transmission is "clicked" into gear. Then go make sure that the shifter is completely in the D position from inside the car. Now go back under the car and see if the cable lines up with the trans arm. If not, adjust it until it does.
Old 05-26-2010, 08:10 PM
timmyz28's Avatar
yeah, my old motor shifted fine at wot and ive gotten it to almost 150. with this new one, it gets to about 115 and doesnt wanna shift to 4th, but you can feel that its ready to shift
  #20
Old 05-26-2010, 09:09 PM
the trans uses the engine readings at wot and vss readings otherwise. also if the shop messed with the trans programing it can mess with the 3-4 shift. what if u shift manually will it go in od?
Quick Reply: Governed LT1 ?!
