Gear Ratio in camaro 98 LS1
Im wondering what gear ratio i would have in the rear end,i called the dealer with the ser# but they said that it didnt tell them.Does anyone know what it would have,i wanna put 3:73 in it that should wake it up a bit.
Thanks Brad.
Thanks Brad.
Thanks thats what i thought around those numbers.Do u think 4:10 will be too much gear for a stock motor?
4.10 will be crazy on an auto, prob max out at about 140ish but get there damm fast, usually 3.73 on auto and 4.10 on manual
code on you door tells you exact ratio, GU2 , GU3 etc etc
think you'll have GU2 for a 2.73
Thanks i will check that out and get back to ya.Oh by the way does my car pic show up when i write ya ,it doesnt show up here.
im gona guess gu5, heres a link to the g codes and there is a sticky in the 4th gen section at the top.
http://www.vibratesoftware.com/html_...ve_axles.htm#G
