Gear Ratio in camaro 98 LS1
Im wondering what gear ratio i would have in the rear end,i called the dealer with the ser# but they said that it didnt tell them.Does anyone know what it would have,i wanna put 3:73 in it that should wake it up a bit.
Thanks Brad. |
2:73/2-series carrier or 3:23/3-series carrier for a automatic and 3:42/ 3-series carrier with the manual. Only 10-bolt ratios available so check your RPO codes or pull the cover.
Originally Posted by blackz87
(Post 458473)
what transmission you got?
Originally Posted by craby
(Post 458497)
4.10 will be crazy on an auto, prob max out at about 140ish but get there damm fast, usually 3.73 on auto and 4.10 on manual
code on you door tells you exact ratio, GU2 , GU3 etc etc think you'll have GU2 for a 2.73 |
Originally Posted by maudyZ28
(Post 458698)
im gona guess gu5, heres a link to the g codes and there is a sticky in the 4th gen section at the top.
http://www.vibratesoftware.com/html_...ve_axles.htm#G |
I would say with an LS1, you probably have 3.42's. That's my wild guess :D
Originally Posted by Chaotic94
(Post 458730)
