fuel trims hellp
Old Mar 10, 2011 | 01:03 PM
auto's Avatar
Default fuel trims hellp
so i changed the o2 sensors today and looked at the live data
at idle long term fuel trims are at +3.4, 3.1
when driving they go to + 7.0, 5.4
do these numbers sound right? they are lower than what they were, and i still get a faint smell of richness but not as much as what i had smelt before.
what else can cause richness? (no pun intended 69)
Old Mar 10, 2011 | 01:31 PM
looks like you have one side running rich or lean. check for exhaust leaks, look for a bad plug wire. have the injectors flow tested and cleaned.
Old Mar 10, 2011 | 01:53 PM
auto's Avatar
i checked the exhaust, couldnt find a leak, dont hear anything either. i changed plugs and wires about 2 weeks ago, i doubt they would go so fast ( msd/delco iridiums)
Old Mar 10, 2011 | 04:09 PM
Fuel trim level are an indication on how much correction the computer is using to keep the fuel mixture in the STOICH range. As long as the adjustments do not run out of range, wich will light up the MIL, the fuel mixture will be correct.
Old Mar 10, 2011 | 04:49 PM
i had my injectors tested trying to find why i was running rich. i had one injector that was not flowing well at all and two more that were weak. i think the computer was riching things up trying to compensate. i was getting a lean and rich code and replaced the 02's which made it go away but like you i was still smelling gas so i thought maybe a stuck injector and had em checked. cost 30 bucks for all 8 to be cleaned and flow tested. i took em off and sent em in.
Old Mar 10, 2011 | 06:37 PM
auto's Avatar
pete-- im not following you too well, so you are saying the spike in the numbers are as it should be?
craby-- i called up south bay injectors, guy said i can drop off the injectors and pick up next day ready to go. so maybe tomorrow i`ll do that, i just hope i get back MY injectors
CFI
Nov 18, 2011 05:56 PM
MonsterZ28
Apr 14, 2011 05:20 PM
LIVE--FAST
70-81 V6/I6 Tech
Mar 14, 2010 01:03 PM
sethscamaro01
Jul 2, 2007 11:21 AM
johnson3034
May 25, 2007 09:35 PM
